Is It True?
Posted 15 August 2017 - 09:28 PM
I read this today and it really shocked me! Are they really THAT small?!
Posted 15 August 2017 - 09:33 PM
Sounds about right, you can put some stuff back in your garage
Posted 15 August 2017 - 09:38 PM
Posted 15 August 2017 - 10:09 PM
Is it true fact that the little old mini is only 4.5ft wide / high and 6.7ft long, weighing in at less than 3/4 tonne all in?!
I thought the mini was 10ft long, 6.7ft sounds a bit too short to me.
Posted 15 August 2017 - 10:31 PM
No they're not that small, the Saloon is 3044mm long, Clubman 3165mm, Estate 3403mm, Van 3314, Pick-up 3314mm and they're all 1580mm wideIs it true fact that the little old mini is only 4.5ft wide / high and 6.7ft long, weighing in at less than 3/4 tonne all in?!
Posted 15 August 2017 - 10:40 PM
weights vary from just over 600-750kg
Posted 16 August 2017 - 12:58 PM
Posted 16 August 2017 - 03:37 PM
Depends how much filler is on itweights vary from just over 600-750kg
Posted 16 August 2017 - 03:42 PM
😂😂😂😂😂😂😂lolololololololol
Posted 16 August 2017 - 04:58 PM
