Mini Long Tre?
Best Answer nicklouse , 16 August 2017 - 01:36 PM
http://www.minispare...h/classic/track rod end.aspx|Back to search
Thanks mate, do you have any idea how much threads/turn will be achieved? Currently have standard length mini ones fitted and they're only on about 5 turns(tracking is currently toeing out)
got a welder? http://www.calverst....sic-priorities/
scroll down to the right part.
Go to the full post#1
Posted 16 August 2017 - 01:19 PM
I believe they're from a Herald?
TIA
Posted 16 August 2017 - 01:30 PM
Posted 16 August 2017 - 01:36 PM Best Answer
Posted 16 August 2017 - 01:44 PM
Thanks mate, do you have any idea how much threads/turn will be achieved? Currently have standard length mini ones fitted and they're only on about 5 turns(tracking is currently toeing out)http://www.minispare...h/classic/track rod end.aspx|Back to search
Perfect, thanks yet again Nick
Posted 16 August 2017 - 02:30 PM
the longer TRE's give about another 5 threads engagement from memory, and also from memory you want 10 turns minimum,
In the past I have used wheel nuts to extend them, as they are the same thread, and already tapered for welding.
Posted 16 August 2017 - 03:52 PM
They even have grease nipples 😄
Edited by cal844, 16 August 2017 - 07:15 PM.
