Electronic Ignition? Starting Issues
Posted 16 August 2017 - 06:32 PM
Posted 17 August 2017 - 12:14 AM
You've not said what year car. Has it got the ballast set up?
I had a similar problem and it turned out to be the coil. Have you tested it?
Posted 17 August 2017 - 07:20 AM
Posted 17 August 2017 - 12:10 PM
Hi James1997,
Has yours been converted? Mines an 89 and was ballast. I've now converted to straight 12v.
Had good results with Lumenition Magnetronic module and Lumenition coil when it had the ballast resistor set-up. Now on 12v set-up, I've got the powerspark module and coil and had no problems with it over the last 24 months. Sorry, no experience on the Optronic though.
Hope this helps.
Posted 17 August 2017 - 12:31 PM
Posted 17 August 2017 - 01:33 PM
Hi James1997,
Hope this helps.
I'm not sure regards to ballast , I've got the electronic ignition fitted I was going to put a oe quality coil from euro car parts along with a new battery In the boot as mine is looking old and mabky do you think this could solve my problem.
Posted 17 August 2017 - 01:34 PM
Hi James1997,
Hope this helps.
Posted 17 August 2017 - 02:07 PM
Posted 17 August 2017 - 03:29 PM
Posted 17 August 2017 - 04:43 PM
Have a look to see if you have a pink/white wire connected to the coil. If you have, its ballast.
Posted 17 August 2017 - 05:04 PM
KernowCooper has done an excellent guide on fitting electronic ignition which might help. He also tells you how to test the coil.
http://www.theminifo...t-step-by-step/
Edited by Its a min, 17 August 2017 - 05:09 PM.
Posted 17 August 2017 - 05:19 PM
It's a min , what make ignition coil do you have ?
This one:
http://www.simonbbc....il-for-the-mini
Edited by Its a min, 17 August 2017 - 05:29 PM.
