Leaded To Unleaded Engine
Posted 16 August 2017 - 07:35 PM
Do I get the 998cc engine block changed from leaded to unleaded or buy a 'new' refurbished engine which has already had the conversion/painting/ fault finding(?) already done?
Price for the latter on Ebay is about the same as the former
Another question, does a refurbished engine reset the clock or does it carry it's existing mileage pre-refurbishment?
Posted 16 August 2017 - 07:38 PM
Be very careful buying off eBay. Do a search on here; there are a lot of horror stories.My engine has done 56k genuine miles, now here's the question...
Posted 16 August 2017 - 07:42 PM
Posted 16 August 2017 - 07:43 PM
Is there anything wrong with the engine as it is?
It's the head that is leaded or unleaded.
Posted 16 August 2017 - 07:45 PM
Nothing wrong with the current engine whatsoever to be honest, it's just not been converted yet.Is there anything wrong with the engine as it is?
It really runs well on unleaded (and additive)
Edit: to clarify, when I said 'block' I meant engine as a whole unit x
Edited by Laurie, 16 August 2017 - 07:47 PM.
Posted 16 August 2017 - 07:46 PM
If by some chance you consider buying off eBay put the details on here because quite a few of the rip off merchants are known to the members.Ok will do, thank you x
Posted 16 August 2017 - 07:47 PM
If it ain't broke, don't fix it.
Posted 16 August 2017 - 07:48 PM
Will do - you Sir are a star! 😀
Posted 16 August 2017 - 07:49 PM
like this guy http://www.theminifo...gz#entry3422027
I would say if the engine is in good heath then leave it as it is and use additive if you want. Personally I don't use the stuff in any of my classics as they don't get thrashed (often) and don't do a lot of miles.
Posted 16 August 2017 - 07:50 PM
Good point well made! 😀
I'll stick with the original plan rather than try and cut corners *thumbs up*
Posted 16 August 2017 - 07:51 PM
Exactly, and they keep changing identities as well.like this guy http://www.theminifo...gz#entry3422027If by some chance you consider buying off eBay put the details on here because quite a few of the rip off merchants are known to the members.Ok will do, thank you x
Posted 16 August 2017 - 07:53 PM
Alternatively just use an unleaded fuel additive like castrol valve master or similar.
As mentioned above, beware of some of the ebay rebuilt engine scams.
Posted 16 August 2017 - 07:54 PM
Jeeeeeze! I think I'll stick with better the devil I know *blink*
Posted 16 August 2017 - 07:58 PM
They're all out there waiting to take your money from you, you're doing the right thing by asking on here first.like this guy http://www.theminifo...gz#entry3422027
