Best 1275 Headset
6 replies to this topic
#1 germini30
germini30
  • 658 posts
Posted 17 August 2017 - 07:59 AM
Is the headset pictured the best available for a 1275mg metro engine? I know it says mpi but apparently the mpi uses better manifold gasket and much better valve stem seals.
#2 nicklouse
  • 17,944 posts
Posted 17 August 2017 - 09:10 AM
the only reason that is MPi is that it has the MPi exhaust gasket and the 2 thermostat housing gaskets. do you reall need them? and does it actually use the MPi spec valve seals?
http://www.minispare...21.aspx|Back to
#3 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 17 August 2017 - 09:26 AM
Become a TMF+ member and you'll get another 7.5% discount off Minispares as well.
#4 carbon
carbon
  • 2,590 posts
Posted 17 August 2017 - 04:50 PM
Minispares do a head gasket set with BK450 for about half that price (£18 plus delivery): https://www.minispar...ts/AJM1140.aspx
But for MG Metro spec engine the Minispares GEG300 head gasket set may be better choice: https://www.minispar.../AJM1141MS.aspx
I would concentrate on quality of the head gasket, in my experience the manifold gaskets are rarely a problem.
#5 racingbob
racingbob
  • 3,061 posts
Posted 17 August 2017 - 04:52 PM
Bk450 gasket is good
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 18 August 2017 - 11:23 AM
I don't use headsets, I buys the gaskets and seals needed for the Job. That way you can select the best quality parts for your build.
Ac
#7 germini30
germini30
  • 658 posts
Posted 18 August 2017 - 01:07 PM
I got an mpi manifold gasket, getting mpi valve stem seals and a bk450
