duplicate.. sorry..
Edited by Mini Waco, 23 September 2017 - 04:30 AM.
Posted 23 September 2017 - 04:25 AM
duplicate.. sorry..
Posted 23 September 2017 - 04:27 AM
Managed to get the Rear Subframe out with only two small challenges. While I thought removing the emergency brake line was going easy, for whatever reason, the R/H side would not pull through. Had to scratch my head a little on that one. Then by accident, I lifted the pivot arm which seemed to free the brake line. Therefore I put a jack under the pivot arm and wha-la.. the emergency brake line pulled through. The second challenge was that I couldn't exactly figure out the connection of the brake line where it goes through the sub-frame. I took me about 30 minutes to figure that out. I was unable to spin the small length brake line out so I had to remove the entire brake junction where it attaches to the frame.
Order of work:
- Removed the shocks
- Emergency brake line disconnected and pulled through the subframe
- Pulled the battery cable through the subframe
- Disconnected the brake lines and removed them from the car
- Thought I had to remove the pivot arm that holds the hub, but then couldn't quite figure out how to remove it from the frame.
- Then I determined that I could remove the frame w pivot arm attached.
Lessons learned.. always wear googles.. laying under the car and looking up. all kinds of rust/dirt fell in my eyes..
A little satisfaction of job complete and the shell is now sitting on a dolly nearly 100% empty. I now feel rather accomplished and have learned a great deal. I am beginning to understand so many posts and articles I've read. I know I've only scratched the surface, but I feel as though I know my Mini now.... Going to my first All British Car Show on Sunday.. I hope to see some Minis there.
Edited by Mini Waco, 23 September 2017 - 04:32 AM.
Posted 24 September 2017 - 01:51 AM
Milestone with a sense of accomplishment.. I now have a rolling shell although there are a few bits and pieces yet to be removed.
Posted 24 September 2017 - 08:20 AM
Loving the annotated photos! This is a great and informative build diary you're compiling here
Posted 24 September 2017 - 10:34 AM
This is a great strip and rebuild thread I just wish I had as much spare space as you do!!
Posted 24 September 2017 - 12:48 PM
thanks MrBounce..
thanks ckneller.. hopefully my novice skills will still help someone else while at the same time helping my own memory.
Posted 24 September 2017 - 05:13 PM
Good point, all those photos will come in handy when it's going back together! Glad to see you're making good progress.
Will you paint it the same color or does your daughter have her own color scheme in mind, since it will be her car?
Posted 24 September 2017 - 05:31 PM
Wow. Just Wow.
Can't believe how fast you are going. I am so envious.
Your rest will be done before my car is stripped at this rate.
Posted 24 September 2017 - 10:19 PM
Since my daughter has claimed this one and doing a good job (so far) of helping, it will be a bright RED (as visible as possible). I hope to make it a more modern version of the mini with side markers and now, thanks to seeing Bruce's Mini, a 3rd rear light. Bruce, any chance you can tell me where you got that one along with the brighter LED bulbs in your rear lights?
Posted 24 September 2017 - 10:20 PM
Wow. Just Wow.
Oh no.. stripping the car is the easy part. Now I have to learn how to remove rust and work on an engine. All clean up next..
Posted 24 September 2017 - 10:25 PM
Haven't done much today because I chose to go to an All British Car Show an hour south of my location. I was hoping to see and get ideas for what I want on my mini. Thanks to a gentlemen I met on another forum, I did learn a few things about the differences between various years of minis. Being nowhere near a Mini rally in England, there were only 7 Minis. To my surprise, they were all R/H steering. I had a good time as it was nice seeing these Minis together.. there were two '65 cars there.. a Mini and a Wolseley.. The white one ('88 Austin Mini) in the picture was one of the cleanest inside and out. by the way, every car was represented from Aston Martin to Lotus to Bentley to MG to TRV, etc.. the best were the Minis !!!
Edited by Mini Waco, 24 September 2017 - 10:26 PM.
Posted 25 September 2017 - 07:05 AM
Hopefully you'll increase it to eight Mini's next year.Haven't done much today because I chose to go to an All British Car Show an hour south of my location. I was hoping to see and get ideas for what I want on my mini. Thanks to a gentlemen I met on another forum, I did learn a few things about the differences between various years of minis. Being nowhere near a Mini rally in England, there were only 7 Minis. To my surprise, they were all R/H steering. I had a good time as it was nice seeing these Minis together.. there were two '65 cars there.. a Mini and a Wolseley.. The white one ('88 Austin Mini) in the picture was one of the cleanest inside and out. by the way, every car was represented from Aston Martin to Lotus to Bentley to MG to TRV, etc.. the best were the Minis !!!
Posted 25 September 2017 - 11:29 AM
I hope you're right Northernpower...
Posted 25 September 2017 - 02:52 PM
I assume it was the one at Round Rock?
Posted 25 September 2017 - 05:20 PM
Edited by 73MkIII, 25 September 2017 - 07:16 PM.
