Rotisserie Woes.. I knew for sure that today would be the day that I would get the shell successfully mounted to the rotisserie.. NOT!! Spending from sun up to 5:30 before I gave up to go mow the grass (before my wife pelted me for having a knee high yard). After it all, I even got sun burned from being out in the sun all blasted day - the sun totally zaps your energy too. It was definitely a 2 steps forward, 1 1/2 steps backward and I'm only a little closer. I have come to believe that I will need a gusset type support beam just to help keep the shell level with the rotisserie arms because the shell wants to sag downward. Therefore I must design an addition to the attachment scheme. While it's not a failure, it was simply a frustrating day.
Lone Star Mini Restoration
#91
Posted 01 October 2017 - 11:38 PM
#92
Posted 02 October 2017 - 08:07 AM
#93
Posted 02 October 2017 - 11:22 AM
That’s a shame. All the jigs I have seen here work like that not sure why you have an issue with the shell sagging, not commonly reported here before shell cutting that is. Strange. Hope you get it sorted soon. Are you going to need to brace the gram anyway? That may change the need for jig modification maybe?
Help me out with definitions please. . "gram"? Does this refer to bracing the shell making sure it does not twist? If so, I've been told by a few people that I trust that the I will not need to brace the shell unless I begin moving body panels. I will figure this thing out.. determined.
#94
Posted 02 October 2017 - 12:06 PM
Edited by 73MkIII, 02 October 2017 - 12:07 PM.
#95
Posted 02 October 2017 - 01:50 PM
#96
Posted 02 October 2017 - 03:32 PM
#97
Posted 02 October 2017 - 03:41 PM
#98
Posted 02 October 2017 - 07:38 PM
#99
Posted 02 October 2017 - 07:50 PM
This video shows it better there is a large frame in the boot
https://youtu.be/4xVz9FXamTo
Edited by 73MkIII, 02 October 2017 - 08:37 PM.
#100
Posted 02 October 2017 - 08:09 PM
I think you need to attach it between damper mounts and parcel shelf, a bit like this: images (2).jpg
Thanks Mac. How is it attached to the parcel shelf? Is there a beam running along the bottom of the shelf and bolted through/to the shelf itself?
#101
Posted 02 October 2017 - 08:38 PM
#102
Posted 03 October 2017 - 10:11 AM
As in the video, you can see a beam across the length of the underside of the shelf and bolted with spreader plates so they don't pull thru and spread the load.beat me to it.
#103
Posted 03 October 2017 - 11:33 AM
Thanks guys... it looks as though I have more steel work ahead of me. So far I've made everything to be disassembled rather than having large heavy steel sections to store when finished. I have a plan in mind already so now just to get the material and work the plan. I greatly appreciate your help MacGyver and 73MK !!!
#104
Posted 15 October 2017 - 09:14 PM
Had to a slight detour with the Mini Restoration. Things that DO NOT mix here in TEXAS.. hard rain & oily asphalt...result.. hydroplane. The downside is that I've been distracted from the Mini. The upside, I get a little body work experience and general car repair experience. I have managed to procure the body parts I need while at the same time meeting some interesting folk. While I'm at it, I figure I will test my learning curve with painting as well.
Posted 15 October 2017 - 10:06 PM
Wondered where you had gone.
Ouch.
Nice car shame about that dent but sure it will polish out.
Put in some practice for the car that matters.
Seriously though it’s only metal as long as everyone is ok.?
