I have the std Metro Turbo cam (I think ), is 108 the number to go for?
Have a nice day!
/Jonas
Posted 29 August 2017 - 08:31 PM
Posted 29 August 2017 - 09:07 PM
Posted 30 August 2017 - 07:21 AM
Regarding chain stretch.
If aiming for 108 some say set at 106 and some say 110.....
Which is right!?
My thoughts is that the number will go up when the cain stretch, so if I want 108 Ill set it at 106 if I expect 2 degrees stretch.
Is that correct?
Posted 30 August 2017 - 08:12 AM
good point and somthing that can catch out even the most experienced!
the cam is timed from the inlet lobe which should be timed 108 deg after TDC, so as its following the crank a lower number is advancing it, so yes I agree with you.
