Which Way Round Does The Rod Change Yolk Go?
Best Answer Deathrow , 31 August 2017 - 12:45 PM
I believe you are referring to this:
As Moke Spider and nicklouse said, it is pictured the correct way up for when the selector is fitted to the car.
It's easy to work out the orientation using the two raised nubs next to either roll pin as it is those nubs that operate the reverse light switch in the housing. If it's upside down it won't reach the hole where the switch enters the housing.
Go to the full post
13 replies to this topic
#1 AeroNotix
AeroNotix
  • 267 posts
Posted 31 August 2017 - 11:39 AM
I've had my rod change out to change some pieces (KAD quick shift, selector bias, bushings etc)
Gone to put it back together and I can't remember which way the actual rod change sits.
It's a kind of bent bar with a cup where the gear stick ball sits.
Does it go:
----    ----    or          _
     \_/               ----/ \----
I've done it the latter way, since that seems to move better than the other way but wanted to be sure before I commit.
Edited by AeroNotix, 31 August 2017 - 11:40 AM.
#2 nicklouse
  • 17,935 posts
Posted 31 August 2017 - 11:47 AM
#3 AeroNotix
AeroNotix
  • 267 posts
Posted 31 August 2017 - 12:00 PM
Ah no, I meant the actual rod that selects the gears. The notched part inside the housing.
#4 Spider
  • 13,904 posts
I think you're referring to the 'eye' or 'yoke' , the alloy do-da that's in the shifter body?
If that's what you're wanting to know, then the normal way it fits up is as per your first sketch when the shifter body is right way up.
#5 AeroNotix
AeroNotix
  • 267 posts
Posted 31 August 2017 - 12:29 PM
Confused now. Do I have it correct or not? I've positioned it so the notch in the yoke is facing upwards.
#6 nicklouse
  • 17,935 posts
Posted 31 August 2017 - 12:43 PM
The cast yoke hangs down.
#7 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 31 August 2017 - 12:45 PM   Best Answer
#8 AeroNotix
AeroNotix
  • 267 posts
Posted 31 August 2017 - 01:34 PM
Looks like I have it correct, then: https://goo.gl/photo...ApChK71fH85K1y7
And also I was misremembering which way I even put it! I did this last night and I should've got to look before asking. D'oh.
Edited by AeroNotix, 31 August 2017 - 01:40 PM.
#9 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 31 August 2017 - 01:47 PM
Hehe.
Did you put the bottom cover on the correct way too?
I had to put mine together and make sure that lift to reverse was bottom right on the stick.
#10 AeroNotix
AeroNotix
  • 267 posts
Posted 31 August 2017 - 01:49 PM
Yeah, I believe so. The gate is the on the first/second side looking down.
#11 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 31 August 2017 - 02:01 PM
That sounds right, the bottom of the gearstick should hit it when you head over for reverse.
#12 AeroNotix
AeroNotix
  • 267 posts
Posted 31 August 2017 - 02:04 PM
Yep! Looks like I've got it all back together folks. Thanks all!
#13 Spider
  • 13,904 posts
Posted 31 August 2017 - 08:33 PM
I doubt you'd be able to re-assemble it with the Eye / Yoke upside down !
Good work all the same.
#14 MrE812
MrE812
  • 39 posts
  • Local Club: ELMOC
Posted 19 March 2020 - 10:55 PM
Meanwhile in the far flung future......
Just wanted to say thanks to this post I've now got a fully functional gearshift.
Yes you can assemble the shifter with the yoke inverted.
What you get is a REALLY sloppy shift in gears 1 through 4 (2nd and 4th were not very positive) and it's impossible to put it into reverse.
Now by the power of KAD my gear selection is second to none.
Stay safe out there kids.
