Popping At Low Revs
Posted 08 September 2017 - 09:29 PM
My exhaust on my classic Mini Cooper sport is popping between 1000 and 2000 revs on the overrun. I don't know what make the exhaust is. I was wondering if it was running too rich or does the ecu sort that out. Also I don't get any smoke from the exhaust. It only does it at low revs. It this just a characteristic of the exhaust?
Thanks,
Daniel
Posted 08 September 2017 - 09:31 PM
Sometimes this can be caused by an air leak in one of the joints.Hi,
Thanks,
Daniel
Posted 08 September 2017 - 09:34 PM
Thanks,
Daniel
Ok so how do I go about checking this. Is their a guide on here
Posted 08 September 2017 - 09:38 PM
You need to be able to get under it, for this you'll need access to axle stands and or ramps to safely work under it. Do you have some?Ok so how do I go about checking this. Is their a guide on hereSometimes this can be caused by an air leak in one of the joints.Hi,
Thanks,
Daniel
Posted 08 September 2017 - 09:40 PM
Thanks,
Daniel
Yes
Posted 08 September 2017 - 09:48 PM
Please make sure you're safe under it.
Posted 08 September 2017 - 09:57 PM
Ok so put it up on the ramps and stands and start it up. Just let it tick over and carefully feel with your hand for any gasses escaping from the joint. This will be confirmed by an area of black soot around the leak. Make sure you just let it tick over, if you rev it the fast flowing gasses will not bleed out through the leaking area they'll simply rush down the pipe.
Thanks I'll try that.
Posted 14 September 2017 - 01:45 PM
If i remember correctly, I seem to recall Sprocket mentioning that on overrun a injection mini will cut fuel, so it naturally burbles a little on the overrun.. Don't quote me on that but thats what I think i remember haha.
My 95 SPI has always burbled and popped a little bit between 1 and 2k on the overrun and it isn't leaking as I fixed that about a month ago.
Posted 14 September 2017 - 02:45 PM
FS
