I've been working at getting the Mini (a 1992 SPI) MOT ready and I'm running into quite some issues, most of them regarding placement or fitting of things.
1. Cutting out a rotten floorpan, I accidently cut through a steel brakeline... So I've been looking for a replacement, but there are lot of types and I'm not sure which one to choose, so if somebody could leave a link of the brakeline I need, that would be perfect. The line starts at a distributor (the one going downwards on the 1st photo/ the left one on the second photo) or something and runs under the righthand side of the car, all the way to the rear wheelarch (see photos). image.jpeg 43.81K 0 downloads image.jpeg 55.06K 0 downloads
2. Staying on the topic of accidently cutting through things, I cut through a brown-blue wire near the exhaust manifold. Does anyone know what it's for? I'm assuming that it plugs onto the connector on the last photo, is that correct?
image.jpeg 76.45K 0 downloads image.jpeg 43.66K 1 downloads image.jpeg 45.51K 0 downloads
3. Then there's the heater. Does the black thing on the first photo go under(green arrow) or on top of the holes/inside the 'box' (red arrow) on the second photo? image.jpeg 27.31K 0 downloads image.jpeg 32.19K 0 downloads
4. The edges of the boot were completely rotten, so I replaced it with the 10" deep replacement plate of Minispares. Unfortunately I had to cut off the tank bracket and I'll have to weld it back in place now. Does anyone maybe have a picture of how it should look like? image.jpeg 49.04K 0 downloads
5. I als found out that there's no rear exhaust bracket for the rubber mounting, so I bought a replacement one to weld on, if anyone had a clear closeup picture of where its mounted, that would be greatly appreciated. image.jpeg 33.4K 0 downloads
6. I'm not sure how to mount the mirrors, am I missing a mounting kit or something maybe? image.jpeg 29.6K 1 downloads
7. And finally the last one, how do you mount the heater cable? image.jpeg 37.44K 2 downloads image.jpeg 36.53K 1 downloads
OK, that was quite a post. Thanks for reading all the way to here, and ifyou know the answer to any of these questions, please let me know!
Edited by muller295, 10 September 2017 - 10:34 AM.
