1997 Promotive Sportspack R1
9 replies to this topic
#1 fiestaharry
fiestaharry
  • 295 posts
Posted 10 September 2017 - 07:53 AM
So finally got round to starting this project, i have had a Sportspack shell up on a rack in my barn that i bought because it was solid but really didnt know what to do with it. As i own another green sportspack i know its quite difficult to get the solid shells.
The plan is to make it a stock looking Sportspack from the outside but with the promotive kit.
I am usually into the mk1 scene (currently owning more than you can count on fingers and toes!) but this will be a nice change.
So lets get going, heres the pictures of as soon as i retrieved it and got it into my workspace,
The main panels it will need are replacement scuttle and dash rail, repairs to front floor corners and both sills, as one side has an oversill and one side has vented.
First job was to strip main panels to bare metal, as this will make the blasting process alot easier later on. (less media used and less distortion to panels)
Next job was to remove scuttle, wings and upper dash rail ready for the new panels to go in, also a small repair on the heater hose hole. Will decide what to do on the shock mounts after the car is blasted.
New panels offered back up
Unfortunately my spot welder arms didnt come in so i had to plug weld all of the holes, which was a shame, i am by no means a professional at bodywork, but i am buying the tools and doing the research to get better, the cleico pins, intergrips and end clamps are great for these sorts of job. I also use a 13mm wide mains powerfile that i never stop using.
I then removed all of the sound deadening from the floor, i didnt want to do it at first so i could keep the original looking floor but was glad when i started going as there was a small amount of water trapped between.
Before:
After:
I used the tools you can see in the last picture, it flew off, maybe because of the water ingress on it.
Thats all for now, i will be attacking the underseal today with a blow torch and scraper and will also get the pictures of the wings etc welded back on.
The plan is to get all the bodywork right, blast the shell myself, as i have a centurywise 3 bag blaster, this will be the 3rd shell i have blasted with great results. Do the etch priming and high build priming and then the paint (which i have never done before but have some knowledgeable friends)
#2 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 10 September 2017 - 08:58 AM
Looks like a good solid shell as a base...
Good luck with the conversion :)
#3 fiestaharry
fiestaharry
  • 295 posts
Posted 10 September 2017 - 10:06 AM
Few more pictures:
On the 360 jig,
Heres the thick horrible underseal, will be repainted in scutz with the gn29 green over the top, should look alot better! Got alot to do before that though
After wire wheeling, blow torching and scraping (the bottom edge was finished after photo was taken)
With the paint stripper applied:
Edited by fiestaharry, 10 September 2017 - 10:07 AM.
#4 fiestaharry
fiestaharry
  • 295 posts
Posted 10 September 2017 - 11:23 AM
the mostly finished floor, ideal now for a quick blast over
#5 racerlike
racerlike
  • 418 posts
Posted 10 September 2017 - 06:07 PM
Nice going. Good luck with the project
#6 fiestaharry
fiestaharry
  • 295 posts
Posted 10 September 2017 - 06:37 PM
thanks, im looking forward to it
#7 thespikeyone
thespikeyone
  • 237 posts
  • Local Club: none yet
Posted 10 September 2017 - 06:51 PM
looks like a tidy shell, should have her on the road in no time.  have fun with the build.  ive never painted before but am in the process painting mine  lot of sanding involved!!!!!
#8 fiestaharry
fiestaharry
  • 295 posts
Posted 10 September 2017 - 07:59 PM
will be worth it in the end hopefully, liked reading your thread before the photobucket problems, as well as alot of others on here
#9 fiestaharry
fiestaharry
  • 295 posts
Posted 11 September 2017 - 08:38 PM
Got the genuine sportspack arches test fitted, looking good! Well worth paying the extra money
#10 Miniowner123
Miniowner123
  • 987 posts
Posted 08 January 2018 - 05:32 PM
While you're doing the bodywork get that front panel to slam panel brace removed as the engine won't clear it. Just done a promotive into MPI shell conversion myself and it's a tight squeeze into the standard front
