Battery Charging Woes
12 replies to this topic
#1 -IR-
-IR-
  • 27 posts
Posted 10 September 2017 - 05:22 PM
Good evening forum, I did do a search before posting but couldn't find anything solid so thought I'd pose my question directly to the hive mind.
I recently bought a rover mini 35 that'd been retrofitted with an earlier carb'd engine, it's had several* electrical faults the most sever of which is that it won't charge the battery.
I replaced the alternator with a high output number from minispares but to no avail, I've checked the earth on the battery and added a second engine earth for peace of mind. When I read the voltage at the alternator itself it's never above 12.5v even when checked differently at the positive terminal and always within about .1 V of what the reading is at the battery.
*Majority of gauge cluster not working, O/S tail light out, N/S headlight out, windscreen wipers were out but I've since tracked that to a dodgy connection and fixed it.
Does anyone have any suggestions for my charging issues?
Thanks in advance,
Indra
#2 nicklouse
  • 17,945 posts
Posted 10 September 2017 - 05:24 PM
Alternator output should be about 14.5V so either you have wiring issues or a faulty alternator.
#3 -IR-
-IR-
  • 27 posts
Posted 10 September 2017 - 05:34 PM
 This was my thinking too, I replaced the alternator with a new one and it's the same.
If I were to disconnect all wires from the alternator then test the live terminal and ground it to my subframe should that eliminate wiring and simply mean I've been sent a dud alternator?
Edited by -IR-, 10 September 2017 - 05:35 PM.
#4 Swift_General
Swift_General
  • 870 posts
Posted 10 September 2017 - 05:55 PM
What's the warning light doing? This needs to earth through the alternator before the engine starts turning to energise the alternator. If there is not continuity there it will never work.
#5 minimans
minimans
  • 411 posts
Posted 10 September 2017 - 05:58 PM
Does the Ign light come on when key turned to Ign? Does it go out when running? The alternator needs a 12V+ supply to excite the windings before it will charge. This is fed through the Ign warning light.
#6 minimans
minimans
  • 411 posts
Posted 10 September 2017 - 05:59 PM
Beat me to it................
#7 nicklouse
  • 17,945 posts
Posted 10 September 2017 - 06:04 PM
and some reading
http://www.theminifo...ng-basic-tests/
#8 -IR-
-IR-
  • 27 posts
Posted 10 September 2017 - 06:05 PM
The light comes on and then stays on when the engine is running, funnily enough it didn't come on at all until I replaced the alternator.
#9 -IR-
-IR-
  • 27 posts
Posted 10 September 2017 - 06:14 PM
 I've gone through this and have everything as it should be but still only 12.5v so no charge going to the battery. Are there common places to find a short?
#10 panky
panky
  • 1,777 posts
Posted 10 September 2017 - 06:18 PM
Has the ignition light been replaced with an LED, wont work very well if it has.
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 September 2017 - 07:33 PM
You beat me to it Nick
#12 andyapanel
andyapanel
  • 564 posts
Posted 20 September 2017 - 02:36 PM
I had this recently on my RSP. It was a Minispares item, too.
Doing the belt tension up tighter than usual solved it.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 September 2017 - 07:48 PM
If you read the link that Keith put up on the Article I wrote then those tests will identify where the fault is, as a mention a short, if you had a short then its a path to earth and on the alternator you'd not have to look for it the smoke trail would identify where.
