Check the condition of the fuel pump inertia kill switch. Known to break down intermittently .
16 replies to this topic
#16
Posted 12 February 2018 - 11:34 AM
#17
Posted 15 February 2018 - 01:41 AM
If the flywheel sensor is bad, there would be an erratic or no RPM reading while trying to start with the problem. The 3000 RPM idle sounds like a vacuum leak in the intake system. Check the brake servo booster and hose for leaks, the Thermac valve system and hoses on intake and the of the air filter housing, the hoses on the oil breathers on the cam timing cover and the clutch cover and finally the hoses going to charcoal canister and its purge control valve.
Everything you need to know is here:
http://www.miniscene...anual_92-96.pdf
Also tagged with one or more of these keywords: engine, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
