Hi all,
I bought http://www.minispare...ssic/TR205.aspx
But i could not remove from paper.
May be it is a stupid question but are there any one to help me how i will? any tricks?
Posted 12 September 2017 - 02:40 PM
Hi all,
Posted 12 September 2017 - 03:04 PM
If its the one that goes on the inside of the window, its a transfer.
Soak in a tray of water until the transfer slides in the backing paper. Slide to the edge of the paper and position where its going on the glass. Hold the transfer in place and slide the backing paper away. Position and blot dry with paper towel.
Just make sure you slide the entire transfer in one go, otherwise it will crease!
Good luck.
Posted 12 September 2017 - 03:06 PM
The BMC 'stickers' are in fact water slide transfers. I suspect it's the same with this one as well - soak in warm water for a minute or two, then slide off into position. Anyone who has ever made an Airfix kit in the past will know what I mean...
Roger
Posted 12 September 2017 - 03:26 PM
Make sure the window is absolutely spotless, otherwise it'll look crap once dry...
Posted 12 September 2017 - 03:28 PM
SAFETY FAST ROSETTE BODY TRANSFER
external sticker as perv the old ECURIE safety fast emblem
they need to correct some wording if it is an internal window sticker.
Posted 12 September 2017 - 03:57 PM
Thank you all,
It is external, but as i understodd same technic i need to do
Edited by KaraKedi, 12 September 2017 - 04:13 PM.
Posted 16 September 2017 - 07:52 AM
Posted 16 September 2017 - 11:29 AM
Posted 16 September 2017 - 12:58 PM
Just some thoughts, never having one of these on a car, although I might like to as they seem rather nice.
Surely the external type doesn't use the water slide technique? It does rain in most places....
Or do you have to apply clear lacquer to seal them?
I remember applying those things to Airfix kits, usually ending up in a mess because they were going on a compound curve and the material had no ability to stretch.
Posted 16 September 2017 - 05:59 PM
I am not driving my car at rainy days. But suggestion is clear lacquer for sealing.
Posted 17 September 2017 - 08:01 AM
Thanks. That makes perfect sense.
Posted 19 September 2017 - 09:30 AM
I don't think laquering is necessary. Mine have never come off and they are not lacquered. Once they dry they don't come off even when the car is washed.
Posted 23 September 2017 - 12:46 PM
I am amazed! But life is full of surprises.
