Hi, 1998 MPI.
Today I had my annual inspection and it turned out that in my emissions I had 2.5% CO (instead of the allowed 0.5%). Only thing I could easily replace for this would be the lambda sensor but as they're bloody expensive I wanted to get a reading on it.
I found a place locally that had a Sykes Pickavant. The lambda sensor voltage is pegged between 1.99 and 2.00 so definitely will be replacing it.
However, I also had a fault code which kept reappearing. The intake air temperature sensor was being labelled as faulty. The value was appearing correct from the live data.
The sensor itself isn't particularly held in well, I can pull it out without needing to unclip it so potentially it's just loose.
Also, if say, the IAT sensor is completely shot how would that manifest when driving the car? I assume it may over/under fuel and affect mileage and/or emissions?
Edited by AeroNotix, 14 September 2017 - 06:15 PM.
