Paint/primer Confusion
4 replies to this topic
#1 harrygillingham
harrygillingham
    Just On Tickover
  • 7 posts
Posted 15 September 2017 - 11:20 PM
Hi everyone,
Just after some advice for when painting time comes around for my 95' SPI once all the welding is done. It has been resprayed at some point in 2k and after researching as best i could the order for painting is as follows;
Bare-metal, fill and smooth all welds and repairs
Scuff/key all other paint
Spray epoxy primer (i was looking at the rust-buster 421 stuff? its iso free and will apparently work with a cellulose top coat?)
Sand and smooth as needed
High build maybe?
Seam seal
Topcoat (cellulose)
Flat and polish
Please let me know if there is a better alternative for any of these steps as this is my first DIY paint attempt
cheers
Harry
#2 pete l
pete l
  • 1,358 posts
Posted 18 September 2017 - 07:56 AM
I've just used some of the 421 epoxy on mine but i painted it on with a brush.
Yesterday I removed a bit of metal that I had already painted a few days ago, because I've decided to change the whole boot floor rather than patch it, and as I was wiggling and bending the metal, the paint cracked and peeled off.
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 18 September 2017 - 02:56 PM
use an acid etch primer on bare metal, it should be thin, then seam seal, the hi-build prime then topcoat.
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 18 September 2017 - 05:50 PM
I find with epoxy primer a very smooth surface is not really ideal to bond to, it should have a shotblasted sa2.5 finish for best results, I always run a da over the surface with a p80 pad on it to help.
#5 pete l
pete l
  • 1,358 posts
Posted 19 September 2017 - 06:37 AM
I will give this a try, thanks
