This isn't a problem with worn bearings or a knackered oil pump (in fact its' the opposite, the engine is in great condition), it's to do with the head gasket. The SC 7 port head uses a different method of transferring the oil from the block to the rockers. You'll see from the photo it doesn't go through the head., it comes up through the normal oil gallery in the block but then it enters a trough machined into the head and travels along the head to the head bolt. It then comes up through the gap between the head bolt and the head and then comes out along another machined trough in the head to the rocker pillar and then up through the pillar as normal. It works very well.
I have an adjustable oil pressure relief valve and I want to know what's the minimum oil pressure I can run to be confident of getting lubrication to the engine. If I run too much it has a tendency to force the oil into the layers of the head gasket. I'm not going to remove the head gasket for a different type.
Discuss
