Wheel Bearings Tools
44 replies to this topic
#1 Laurie
Laurie
  • 298 posts
  • Local Club: GMOC
Posted 20 September 2017 - 10:46 AM
I'm not doing it yet!
But I want to get tooled up and ready, I was going to be working on all wheels and changing the gaiters as needed probably at around the same time? I've NEVER done this before by the way so I'm more than a little bit scared :lol:
I've been Ebaying tools and two seem to show up - a puller and rings, so do I need these? Anything else for the shopping list if you like?
My mechanical experience lies as far as simple stuff so I'm throwing myself into the deep end a bit here so any tool likely to make things easier will be willingly appreciated
Bog standard torque wrench, spanners and sockets etc I've already got, also got a handy power (not air but same kinda jobby) wrench somewhere :D
Edited by Laurie, 20 September 2017 - 10:47 AM.
#2 nicklouse
  • 17,944 posts
Posted 20 September 2017 - 10:51 AM
to be honest it depends on the condition of the bearings and what is wrong with then.
normally a drift and a hammer is all I use. BUT sometimes an Angle grinder was needed to remove the inner race on the CV.
#3 Laurie
Laurie
  • 298 posts
  • Local Club: GMOC
Posted 20 September 2017 - 10:55 AM
One of the bearings is going I know that from past mots, but I can't remember which one :ermm: so I was going to do all of them
An angle grinder sounds like tremendous fun, we've got one of those as well. Metal cutting or grinding disc?
Also I don't want to sound thick here, but what's a drift?
Edited by Laurie, 20 September 2017 - 10:56 AM.
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 20 September 2017 - 11:00 AM
If you read the Haynes you find a good description of how to replace the bearings without using a puller, its not as difficult as it sounds. You may have a little problem removing the rear hubs.
#5 RooBoonix
RooBoonix
  • 1,224 posts
Posted 20 September 2017 - 11:17 AM
Make sure your torque wrench goes high enough, and if reversible (so it can apply torque onto left hand threads), I think you need one going up to around 250-300nm I can't remember the exact torque off hand.. that's for single hole front CV's
Edited by RooBoonix, 20 September 2017 - 11:17 AM.
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 20 September 2017 - 11:26 AM
Drifts come in all sorts of sizes and styles. You need one to punch out the outer bearing race from the hub.
#7 nicklouse
  • 17,944 posts
Posted 20 September 2017 - 11:28 AM
often a short rod of a metal. normally softer that what it is being pressed against. think chisel or punch pin. could even be a bit of wood.
for example refitting the bearing races into the hub, you will need to make sure they are seated fully so they will need pressing in. or you could knock them in around the sides but you don't want to cause an damage.
removing the races would also need something similar.
Haynes manual read.
#8 Laurie
Laurie
  • 298 posts
  • Local Club: GMOC
Posted 20 September 2017 - 11:45 AM
Would this work?
Wheel Bearing Removal and Installation Kit https://www.amazon.c...i_lsLWzbAWMGTQV
#9 nicklouse
  • 17,944 posts
Posted 20 September 2017 - 11:49 AM
Would this work?
nope
#10 Laurie
Laurie
  • 298 posts
  • Local Club: GMOC
Posted 20 September 2017 - 11:55 AM
K what about this
http://www.halfords....1&storeId=10001
#11 Cooperman
  • 23,039 posts
Posted 20 September 2017 - 12:11 PM
One of the small problems is pressing the new outer races into the hubs.
A good trick is to lightly grind down the outer diameter of one of the old outer races so that is just slides into the hub. Then use this to press the new outer races fully home in the hubs. Just use a grinding disc on an angle-grinder and work your way around the outside of the old race.
#12 nicklouse
  • 17,944 posts
Posted 20 September 2017 - 12:12 PM
nope.
from your Haynes manual rear bearings
1 Chock the front wheels then jack up the rear
of the car and support it on axle stands (see
“Jacking and vehicle support”). Remove the
rear roadwheel, then release the handbrake.
2 Slacken off the brake adjuster, unscrew the
two brake drum retaining screws and lift off
the drum. If it is tight, tap it gently using a softfaced
mallet.
3 By judicious tapping and levering, extract
the hub cap and withdraw the retaining split
pin from the hub securing nut (see
illustration).
4 Using a large socket, undo and remove the
hub securing nut and thrustwasher. Note that
the left-hand hub nut has a left-hand thread
and the right-hand hub nut has a right-hand
thread.
5 Withdraw the hub from the stub axle using
a hub puller. Alternatively, lever it off using
two stout screwdrivers or flat bars.
6 With the hub assembly removed from the
car, prise out the rear oil seal, then tap out the
two bearing inner races using a brass drift.
Take care not to lose the balls which will be
released as the inner races are removed. On
certain models, taper roller bearings are fitted
and the inner races are simply lifted out.
7 Withdraw the distance piece (if fitted)
located between the two bearings and then
drive out the two outer races away from the
hub centre.
8 Thoroughly clean all the parts in paraffin or
a suitable solvent and dry with a lint-free
cloth.
9 Carefully examine the bearing inner and
outer races, and the ball cage and balls for
scoring, pitting or wear ridges; renew as
necessary. The hub oil seal must be renewed
as it will have been damaged during removal.
If the bearings are in a satisfactory condition,
reassemble the balls and ball cage to the
outer race and then press the inner race back
into position.
10 Before refitting the bearings remove any
burrs that may be present in the bore of the
hub. Use a fine file or scraper.
11 Pack the bearings using a general
purpose lithium based grease and fit the
inboard bearing to the hub with the narrow
edge of the bearing outer race facing away
from the hub centre. Press or tap the bearing
into position, using the outer race only, with a
tube of suitable diameter until the bearing
abuts the shoulder in the hub. Take great care
to keep the bearing square as it is installed,
otherwise it will jam in the hub bore, and could
cause the outer race, to crack.
12 Fit a new oil seal to the rear of the hub
with its lip facing towards the bearing. On
models fitted with taper roller bearings, the oil
seal lip faces away from the bearing.
13 Place the distance piece in position and fit
the outboard bearing into the hub, again
ensuring that the narrow edge of the bearing
outer race faces away from the hub centre.
Note: Some makes of plain ball-bearings have
lengthened inner races which butt against
each other. In this case the bearing distance
piece is no longer needed.
14 With the bearings installed, refit the hub to
the stub axle and gently tap it home using a
soft-faced mallet. Ensure that the stub axle
squarely enters the distance piece between
the two bearings.
15 Place the thrustwasher over the stub axle,
chamfered side toward the bearing, then refit
the securing nut and tighten it to the specified
torque. Align the next split pin hole and fit a
new split pin.
16 Refit the hub cap, brake drum and
roadwheel, readjust the brakes (see Chapter 1)
then lower the car to the ground.
#13 nicklouse
  • 17,944 posts
Posted 20 September 2017 - 12:15 PM
Disc brake models
19 Remove the swivel hub assembly as
described in Section 3.
20 With the assembly on the bench, lift off
the tapered collar (fitted to certain models)
from the front of the outer bearing and then
prise out the two oil seals using a screwdriver.
Now lift out the inner bearing spacer, the two
taper roller bearings and the distance piece.
21 Using a suitable drift, tap out the two
bearing outer races from each side of the hub.
22 Thoroughly clean the bearings and swivel
hub using paraffin or a suitable solvent and
dry with a lint-free rag. Remove any burrs or
score marks from the hub bore with a fine file
or scraper.
23 Carefully examine the bearing outer races,
the rollers and roller cages for pitting, scoring,
or cracks, and if at all suspect renew the
bearings. It will also be necessary to renew
the oil seals as they will have been damaged
during removal.
24 Begin reassembly by refitting the bearing
outer races to the hub, with their smaller
diameter toward the hub centre. Press the
outer races into the hub using a tube of
suitable diameter and a vice, or very carefully
tap them into place using a brass drift. Ensure
that the race does not tip slightly and bind as
it is being installed. If this happens, the outer
race will crack so take great care to keep it
square. The outer race must seat firmly
against the shoulder in the centre of the hub
when fitted.
25 Pack the two roller bearings with a high
melting-point grease and position them in
their outer races with the distance piece in
between.
26 Install the two new oil seals with their
sealing lips inwards and use a tube of suitable
diameter to tap them fully home. Note that
there is a spacer fitted behind the inner oil
seal and that the inner seal also has a second
lip on its inner circumference.
27 Position the tapered collar over the outer
bearing (where fitted), and refit the swivel hub
assembly to the car as described in Section 3.
When refitting the swivel hub, ensure that the
water shield on the driveshaft is packed with
grease around its sealing face and positioned
6.35 mm from the end of the shaft.
the only tools needed are may be a hub puller and a brass drift.
as above using a machined down race can be good. or a suitable bit of tube or a gert big socket or take time with hammer and brass drift.
#14 Laurie
Laurie
  • 298 posts
  • Local Club: GMOC
Posted 20 September 2017 - 02:19 PM
I've just bought some hardened steel drift punches, they were only cheap from toolstation so I'm not overly concerned if they're wrong
I'll get myself a puller as well - any recommendations?
Hammer we've got tonnes of, from overboard sledgehammer right through to a little pin hammer
Could I use a dremel with a grinding disc on the race joint? As I fear I might get carried away with a angle grinder :ermm:
Edited by Laurie, 20 September 2017 - 02:19 PM.
#15 nicklouse
  • 17,944 posts
Posted 20 September 2017 - 02:22 PM
not a fan of hard drifts for re fitting as they can cause damage. dremel would take years.
