Posted 22 September 2017 - 10:13 PM
I have a 1994 Mini 35, it has a 1275 engine.
Currently have the engine out of the car while all the body work is being carried out. Friends of mine have recommended that I change the clutch while I have it out, and said I should get a LuK one. Looking for opinions on this as they seem to be very pricey, and being that my car will do minimal mileage etc. I wondered if this was 'overkill' or still worth going for? At a whopping £270 compared to a Sax one at £135 (which a supplier suggested was basically just as good).
What have others used, what should I be looking for? - Max (learning as I go along!)
Posted 22 September 2017 - 10:27 PM
well the clutch friction plate is only about 40 pounds.
but if you are doing the friction plate and the spring cover and the release bearing then about 110 to 120 but dont forget you will need to have the clutch assy balanced if you change the spring cover.
so friction plate 40 quid release bearing and O ring about 6.50.
o ring
release bearing
friction plate 1990 on
190mm
and if you join TMF+ for 5 quid a year you get 7.5% discount from Minispares.
Posted 22 September 2017 - 10:39 PM
so you kinda need to ask what are you actually getting for all that money.
Posted 22 September 2017 - 10:55 PM
That's fantastic thanks for the links, I will enquire as to what actually comes in the kits I was quoted for (LCP Automotive components) just for reference but if the parts you mentioned are the parts essentially needed to overhaul my current clutch then fantastic.
Would this be of reasonable quality? (I believe mini spares supply Valeo)
Posted 22 September 2017 - 10:56 PM
Posted 22 September 2017 - 11:11 PM
I would trust Mini Spares, buy with confidence, But as Nicklouse has suggested pay a fiver for TMF + membership and get a great discount from Mini Spares - and others
Posted 26 September 2017 - 03:59 PM
Not a case of hearing the words "classic mini" and jacking the price up 100%???
Posted 26 September 2017 - 04:29 PM
Edited by whistler, 26 September 2017 - 04:30 PM.
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
