Hope to get some help with this.
I have installed an mpi engine and loom into an 89, it came from my own running driving car.
I have installed a good battery from another car it reads 12.80 volts when disconnected and holds the charge.
When I have it connected it I get a slight voltage drop.
At the starter and alternator I am reading around 9 volts and the dash gauge also shows around the same.
The reading at the alternator which is a brand new unit is fluctuating
My fuel pump is not engaging as normal with the first turn of the key (maybe needs a 12v signal)
The engine will turn over
The battery is drained to around 10/11 volts after 30 minutes and that's with no cranking over time.
So far I have checked and cleaned all the earth points, tried a different battery checked all my plugs are tight.
Any advice would be great, thank you
Edited by Club man, 26 September 2017 - 10:27 AM.
