Dry Spark Fouling On Two Cylinders
7 replies to this topic
#1 Daniboy3433
Daniboy3433
    Starting My Mini Up
  • 2 posts
Posted 26 September 2017 - 07:20 PM
I have a 72 clubman with 998cc engine. Have rebuilt the engine and after the build didn't drive the car for over a year. When I fired up the engine fo
#2 Daniboy3433
Daniboy3433
    Starting My Mini Up
  • 2 posts
Posted 26 September 2017 - 07:23 PM
So to continue... cylinder 1 and 4 look fine and 2 and 3 are fouling and no sign of any compression. Has new head gasket after rebuild. Car is running on two cylinders. Need help. Thanks
#3 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 26 September 2017 - 07:25 PM
Have you checked the valve clearances?
#4 slidehammer
slidehammer
  • 1,081 posts
  • Local Club: LSMOC
Posted 26 September 2017 - 08:21 PM
If the engine hasn't been run you could have rings sticking in their grooves. You could put some oil down the bores and see if the compression improves. Also check the valves aren't sticking in the valve guides, you would see that with the rocker cover off.
#5 Homersimpson
Homersimpson
  • 802 posts
Posted 27 September 2017 - 03:14 PM
Have you got the plug lead rotation the right way around?  I've seen quite a few cases where the centre leads have been swapped over resulting in very poor running and diagnosis of doom and gloom, swapping the leads around and everything was well (and a few red faces on some people).
#6 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 27 September 2017 - 10:39 PM
Make sure the valves are not stuck open. If you check the valve clearances this will tell you. You probably need to check the compressions wet and dry, this could also tell you if the rings have gummed up.
#7 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 28 September 2017 - 08:56 AM
I'd second the plug lead swap .. just double check it by pulling the rocker cover, get No1 valves to be fully closed on a compression stroke and see where the rotor arm points too. 1,3,4,2 from there.
My pals 850 would not start one cold damp morning, so he pulled the plugs to check everything ..he put everything back together and only had enough battery charge to just turn it over ...it started!  But he had put the leads on wrong (missing on two), so instead of switching it off he swapped the plug leads with it running ...two leads at a time, one lead in each hand! Said his arms hurt for hours afterwards with the shock ...god we laughed at him demonstrating in slow motion pulling the leads off in twos and swapping them as he was slowly electrocuted.
#8 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 28 September 2017 - 10:51 AM
Interesting, the OP has not logged in since his second post when he asked for help, perhaps he's stuck in the middle of nowhere.  :D
