Door Hinges
Posted 26 September 2017 - 07:25 PM
Any ideas on the best repair to do on these, thanks
Posted 26 September 2017 - 07:35 PM
I think you should be able to grind the weld off the back of the stud, drill out the stud and re-thread it, Add new studs and weld them on.
Posted 26 September 2017 - 08:09 PM
Here is how I repaired mine, you need a mig, which I assume you would have if you are replacing the A panel,
First I separated the 2 halves by punching out the roll pin. Then I heated the old stud up to red hot and let it cool gradually as the fact there were welded in has made the metal very hard and difficult to drill the old stub out, so this heating relaxed the metal again . Then I filed the broken stud flat so I could centre punch it and the gradually drill the old stud out
you can see one has been done and the other is being drilled out.
Next I bought some imperial bolts with the correct thread and hack sawed off the heads and then using an old nut as a spacer made sure the back of the bolt was recessed (to allow space for the weld pool) clamped it with a spot weld clamp.
Then filled up the back with weld (you want the welder set quite hot as it a thick piece of metal you are welding. Then I removed the nut I was using as a distance piece. Reassemble with roll pin and a lick of paint and the jobs a good in. good luck
Posted 27 September 2017 - 06:11 AM
Excellent work and nicely explained - pics are great too.
Posted 27 September 2017 - 08:28 AM
