Just started year 2 of a foundation degree in Automotive Engineering and we have to do a major project. I have a 998 A+ engine which want to dyno > rebuild the engine/head (maybe blueprint) > dyno > modify head > dyno again. They have an engine dyno at college but not sure if they will let me use it yet and even tho i want to engine dyno it I want to get everything so its ready to put in the mini,
There are loads of bits missing from the engine and I need to make a list of all parts and tools required so I can plan the build, looking for help/advice with this :)
Tools
DTI gauge - i bought one but not happy with the quality
Magnetic stand - HAVE
Flywheel puller
1.5" socket
Engine crane - ordered
Engine stand - ordered
Timing wheel
Valve spring compressor
Parts
Starter motor
Alternator
Distributor
Oil filter
Oil
Coolant hoses
Coolant res
Coolant
Water pump
Thermostat
Radiator
Air box - might still have the original
Air filter
Carburettor - believe it should be hs4
Fuel filter
Fuel hose
Ideally i want to use all the pistons and shells etc for the first dyno run then rebuild with new. Same with the head, use what is there then rebuild with new.
Will have to start looking for a company that can do the engine dyo if college wont, dip the head and block and also convert the head to unleaded.
I have attached some pictures and you can see some slight damage to the block.
Any help/advice is much appreciated :)
