998 Engine Rebuild
7 replies to this topic
#1 flatline
flatline
  • 247 posts
Posted 26 September 2017 - 09:48 PM
Just started year 2 of a foundation degree in Automotive Engineering and we have to do a major project. I have a 998 A+ engine which  want to dyno > rebuild the engine/head (maybe blueprint) > dyno > modify head > dyno again. They have an engine dyno at college but not sure if they will let me use it yet and even tho i want to engine dyno it I want to get everything so its ready to put in the mini,
There are loads of bits missing from the engine and I need to make a list of all parts and tools required so I can plan the build, looking for help/advice with this :)
Tools
DTI gauge         - i bought one but not happy with the quality
Magnetic stand -  HAVE
Flywheel puller
1.5" socket
Engine crane - ordered
Engine stand - ordered
Timing wheel
Valve spring compressor
Parts
Starter motor
Alternator
Distributor
Oil filter
Oil
Coolant hoses
Coolant res
Coolant
Water pump
Thermostat
Radiator
Air box - might still have the original
Air filter
Carburettor - believe it should be hs4
Fuel filter
Fuel hose
Ideally i want to use all the pistons and shells etc for the first dyno run then rebuild with new. Same with the head, use what is there then rebuild with new.
Will have to start looking for a company that can do the engine dyo if college wont, dip the head and block and also convert the head to unleaded.
I have attached some pictures and you can see some slight damage to the block.
Any help/advice is much appreciated :)
#2 flatline
flatline
  • 247 posts
Posted 27 September 2017 - 08:54 AM
Found this carb, the same seller has one with a red jet for the same price. Which one is standard?
http://www.ebay.co.u...353.m1438.l2649
#3 CAU998
CAU998
  • 1,202 posts
  • Local Club: TMF South Central...
Posted 27 September 2017 - 09:12 AM
Originally this engine would be fitted with a HS4 waxstat jet carb. Albeit either would work and most find the pre-waxstat carbs are less troublesome. The waxstat jet was brought in from what I've heard to tackle emissions issues.
#4 flatline
flatline
  • 247 posts
Posted 27 September 2017 - 06:39 PM
Bought the carb listed above :)
Any recommendations on the spark side of things? Ill have a look but i'm pretty sure I don't even have spark leads and plugs and there are so many different distributors which vary in price :)
#5 CAU998
CAU998
  • 1,202 posts
Posted 28 September 2017 - 12:28 PM
Standard 998 A +, would have a 59d as standard or a ducellier. The 59d is the distributor to go for (ducellier was short term and isn't well catered for), even if you're looking to modify it can be recurved and converted to electronic ignition for reliability. BP6ES plugs are the plugs to go for and a good set of leads from any supplier will be more than adequate, Minispares C-27H7779 leads are a good option, without breaking the bank.
Edited by CAU998, 28 September 2017 - 12:29 PM.
#6 flatline
flatline
  • 247 posts
Posted 05 October 2017 - 06:39 PM
Spark plugs,engine crane, engine stand and carburettor have all been delivered. Will get some pics up over weekend :)
Picked these parts, look good?
http://www.minispare...|Back to search
http://www.minispare...px|Back to shop
#7 CAU998
CAU998
  • 1,202 posts
Posted 10 October 2017 - 04:06 PM
Sorry hadn't seen your reply. All looks good, apart from the distributor ideally needs to be an ADU5789. Which has the correct advance curve for a standard 998. Also the coil is fine providing the car is using a ballast ignition wire (aprox 82-92 998's)?
#8 Preertybrub
Preertybrub
    Just On Tickover
  • 6 posts
  • Local Club: Preertybrub
Posted 01 April 2018 - 05:16 PM
What a transformation well don Al looks mint. Did you go back to the engine fan instead of the thermos?
