Hi everybody,
I have a 1993 Cooper SPI, running on 4.5x12" std wheels with 165/60/12 Yokos.
It is fitted with fully adjustable suspension:
> adjust-a-ride Hilos front & rear
> adjustable front lower arms and tie rods,
> camber and toe rear brackets,
> solid mounts to subframe (aluminum tower pads and front teardrop mounts)
I intend to use the car for fast road and mountain rally (100's of turns :) ) so I have been confused
about what geometry settings I should use. My thoughts are:
Front
Camber: -2 deg
Caster: +3.5 or 4 deg
Toe out: -3 mm
Rear
Camber: -1 deg
Toe in: +1.8 mm
How does this sound to you?
Thanks!
Edited by telias, 30 September 2017 - 12:11 PM.
