Replacing The Entire Front Windscreen Surround - Anyone Done It?
Posted 30 September 2017 - 04:40 AM
Posted 30 September 2017 - 06:51 AM
Link to my thread page 17 it starts towards bottom of this page
http://www.theminifo...-cooper/page-17
Posted 30 September 2017 - 09:21 AM
I've posted a guide from when I replaced mine last year.
Like Daz said, bracing isn't really needed, but I did get a bit of a bulge outwards - easily corrected with a bit of careful pushing / shoving / hammering.
I did not deseam mine though, so it was much more straightforward.
If you get the Heritage panel, you will have inner A post panels & upper roof strengthener already welded in place (plus a brace keeping window aperture from collapsing).
Can't hyperlink this, but you should be able to cut & paste (or search for "front windscreen panel replacement")
http://www.theminifo...1/#entry3440882
Good luck
MA
Posted 30 September 2017 - 07:43 PM
I replaced full surround on my mk2, didn't do any additional bracing. Only problem I had was the inner a post panels I had to remove from the panel and fit after it was in place as it wouldn't fit with them on, think in factory it was assembled with side panels and without roof in place, other issue which is mk1 and mk2 specific is the inner rail corner sections are different so I had to use original ones off the car. Other than that it fitted fine.
Thank you! Great thread you have :)
Good luck
MA
Much appreciated - thank you!
