hello, i dont normally ask these sorts of questions, but i am wondering what value these items have:
remote change gearbox casing, "tunnel" casting complete, other bits to make a kit to convert a mini
Posted 01 October 2017 - 07:14 PM
Posted 01 October 2017 - 07:16 PM
i should say that i bought all this about 20 years ago from a reputable secondhand parts supplier and they've sat in my shed unused till now
Posted 02 October 2017 - 06:06 PM
The 22G846 casing is for 4-syncro, and is essentially the same as the 22G1128 casing which is now getting in short supply as they were only used for about 5 years, and even then only on some models. The main points to check are alignment of the gasket and bored faces in the diff housing, as they should be a matched pair. If all is in good order the casing should be worth £100 or more.
Posted 02 October 2017 - 07:11 PM
thanks
Posted 03 October 2017 - 12:06 PM
