Bracing The Shell - Typical Box Section Dimensions To Use?
7 replies to this topic
#1 g111mds
g111mds
  • 432 posts
Posted 02 October 2017 - 12:30 PM
As the Pup nears complete strip down to a bare shell my thoughts are starting to turn to bracing ready for working through the various major repairs (door frames for example). Question really is around what dimensions for the box section would be appropriate? 25mm by 25mm, or better still something like 30mm by 30mm? I'll need to be ingenious with how I do it and will likely go over the top just to make sure, but keen to brace it with something appropriate.
Thanks, Jamie
#2 73MkIII
73MkIII
  • 158 posts
Posted 02 October 2017 - 12:50 PM
Someone posted 20mmx20mm as adequate the other day. Square inside the pillars with a vertical support welded to the cross member. Will be interesting to hear experienced people’s comments on this.
#3 73MkIII
73MkIII
  • 158 posts
Posted 02 October 2017 - 01:17 PM
Think it was the thread on replacing sills
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,885 posts
  • Name: Neil
Posted 02 October 2017 - 03:17 PM
I use 20mm x 20mm and as mentioned square across the pillars and across the door frame. Also i had another section across the crossmember with drop down to the crossmember. A couple of diagonals would not hurt either.
#5 g111mds
g111mds
  • 432 posts
Posted 02 October 2017 - 09:51 PM
Thank you both. I'll get some ordered.
#6 GT Jimmy
GT Jimmy
  • 1,582 posts
  • Local Club: S.U.N.M.C
Posted 04 October 2017 - 06:52 PM
I used an old metal bed frame for mine, did the trick. Best bit it was free
#7 mattmiglia
mattmiglia
  • 515 posts
Posted 04 October 2017 - 07:09 PM
20 x 20 I went for
#8 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 04 October 2017 - 10:28 PM
Ermm whatever you can lay your hands on for the lowest cost!
