Suffolk Newbie
Posted 07 October 2017 - 10:36 AM
So this pickup had had panel work done to it, now I'm not a bodywork man so I'm going to send it to a bodyshop to get the work checked. So now I'm at the stage of subframes and brakes and I've just had the rear subframe sandblasted and am looking at powder coating. By the way can anyone give me some advice on radius arm removal as I'm struggling....assuming you can't powder coat the whole subframe.
In fact any recommendations for mini businesses in Suffolk (UK) appreciated! Engine and gear box also need overhauling.
Thanks in advance and pics will follow
Posted 07 October 2017 - 10:59 AM
Whereabouts in suffolk are you?
Posted 07 October 2017 - 11:18 AM
Remove shock absorber, disconnect brake lines, undo the nuts on either end of the pin, remove the four bolts holding the little bracket to the outer end of the subframe, give the radius arm a wiggle to release the knuckle joint and it should lift right out.
Posted 07 October 2017 - 12:55 PM
Wingnut I'm in Clare near Sudbury
Posted 07 October 2017 - 12:57 PM
Thanks Panky I'll give it a go!!
Posted 07 October 2017 - 01:33 PM
Ok nice one.I've got a pickup and i live in bury st edmunds,so not far from you.
Posted 07 October 2017 - 04:52 PM
Posted 07 October 2017 - 07:08 PM
yes and its a t reg!.Its only got an 850 but for the miles i do in it thats ok
Posted 08 October 2017 - 08:04 AM
Panky you're a genius... thanks
Posted 08 October 2017 - 08:19 AM
Did it last week
Posted 08 October 2017 - 03:57 PM
Posted 08 October 2017 - 04:16 PM
Hard target to find
