Morning all,
After some advise or some recommendations for a full suspension set up.
i've recently got a 95 Sprite that came on a moulton smooth ride kit, but with very very tired shocks.
i've replaced a fair bit of the suspension, but need a base line to work with as i've still got some minor issues to work around.
i've changed to the following:
spax lowered adjustable shocks (set 10/28 on the front, and 22/28 rear)
adjustable hi-lows at the rear (got the front, but not done yet as i've not had the time to remove the ones with the moulton kit.)
1.5 deg neg camber front lower arms
group a adjustable tie rods
camber and caster adjustable rear brackets
still got the moulton cones on front and rear as i've not got the tool to remove them yet, but possibly planning on replacing with the standard (or maybe uprated)
The car is running on 12s at the moment with 145 tyres for the winter, but will run 165 tyres for the summer with stickier rubber!
Problem i'm getting is a scrubbing on the rear end that is noticeable on rougher roads and a general lack of feel from the front.
i think i either need a suggestion for a base setting (but i dont know how much variance i have in the body)
or is anyone knows a good place to get the whole thing checked and set up fully.
Any advice is appreciated.
Peter
