I'll have another guess. Did the MPI engine come with a cat exhaust?
Best Answer AeroNotix , 14 October 2017 - 04:39 PM
I found the name, it's the purge valve. It's behind the coolant tank as I said. Should be the bolt for the purge valve's bracket. Looks exactly like it!
http://www.minispare...~.aspx?2~12~117
Part 16 and 22 here.
Go to the full postPosted 14 October 2017 - 04:17 PM
Posted 14 October 2017 - 04:22 PM
Posted 14 October 2017 - 04:31 PM
Edited by WillCarter, 14 October 2017 - 04:33 PM.
I know what it's for but I don't know what the part is called. Behind the coolant tank there's a doodad with an electrical connection that mounts on a bracket. It has fuel lines(??) going to it. That "nut" is a bush that is pressed into that bracket and the bolt goes into that. I can get a picture if you need.
It's a shoulder bolt.
As in, the one bolt you have left over and then chuck over your shoulder to get rid of it!
Posted 14 October 2017 - 04:38 PM
Edited by WillCarter, 14 October 2017 - 04:41 PM.
Posted 14 October 2017 - 04:39 PM Best Answer
Edited by AeroNotix, 14 October 2017 - 04:40 PM.
Posted 14 October 2017 - 04:41 PM
Posted 14 October 2017 - 04:58 PM
No longer available - worth a fortune
Posted 14 October 2017 - 05:43 PM
Posted 14 October 2017 - 05:44 PM
Is it possible to have just be a bolt that’s accidentally been mixed with the rest?
Posted 14 October 2017 - 05:49 PM
Posted 14 October 2017 - 05:50 PM
Quick! Purge it out the garage!
Posted 14 October 2017 - 05:54 PM
Posted 14 October 2017 - 05:58 PM
