To start I have a 1998 Mini Mpi
So I finally decided to take the car apart to find out where the water in the foot wells is coming from, the bulkhead always looked completely dry when looking before so I assumed it was something else, though the scuttle did look rusty I have sealed and leak tested it and it seemed to fine so I ended up taking the dash out and poked around and found these holes
Drivers Side Vent
Passenger Side Vent
(In the wheel arch water was also dripping between where the scuttle and wing meet)
I also found the door seals like this which was causing water to run down the door stops and into the car on both sides.
Also water was running into the outer window seal and through the door and out of the bottom, I think some of this was getting in but Im not too sure. (picture below shows it on the outside of the window, its raised higher than it should be)
Can anyone suggest on how to fix these problems in the easiest way possible? And which parts to buy and if there could be any other places the water could be coming it? I do have access to a welder and can fabricate new metal parts if required.
Any help would be appreciated
Alfie.
Edited by AlfieHopkins, 16 October 2017 - 03:05 PM.
