Collecting An Engine Block
Posted 17 October 2017 - 06:23 PM
No carrier I can find will touch one without it being on a pallet which is £65.
It's just a 35 kg block not a whole engine - can anyone recommend a carrier?
Thanks.
Posted 17 October 2017 - 06:39 PM
Posted 17 October 2017 - 06:45 PM
Items over 20 or 25kg (not sure which) cannot be handled by hand. They have to be able to be moved/lifted etc by mechanical handling methods. i.e. a forklift; hence your answer regarding palletization.
+1
25 iirc
had the same argument a few years ago
Posted 17 October 2017 - 06:54 PM
Just checked their T&Cs - https://direct.tnt.c...ht-restrictions
and they should be able to help you.
Edited by DJS911, 17 October 2017 - 06:56 PM.
Posted 17 October 2017 - 06:59 PM
Posted 17 October 2017 - 07:12 PM
I tried TNT but engines are on their 'naughty items' list.
Assuming that it’s well wrapped so it’s not obvious as to what it is could you describe it as a “metal casting” perhaps?
Posted 17 October 2017 - 07:24 PM
You can try getting a quote on shipply for quotes and someone will help you there
OR
Paisly freight but they will probably want a pallet
Posted 17 October 2017 - 07:29 PM
I
It's not an engine, it's a component. The reason they don't do engines is that they contain oil and other hazardous substances.
Posted 17 October 2017 - 08:46 PM
You never know then, I will contact them and see what they say.
Could always describe as a boat anchor, paper weight or door stop lol.
Posted 18 October 2017 - 12:59 AM
I think these days 20 kg is the cut off limit.
They'll take if if not on a pallet, but must be 'forklifable' meaning, you need to be able to get fork tines under it. I often use 'skids' for this which are a 1/4 size pallet.
Also, being what it is, if I can say, you do want it packaged carefully and appropriately so it doesn't get damaged in transit.
Edited by Moke Spider, 18 October 2017 - 01:00 AM.
