1992 Spi Jdm Auto Engine Dies When Hot
Posted 19 October 2017 - 12:44 AM
Has been like this for a few months, driving rarely, not stopping. But yesterday after ~10kms at 100kmph I lost power ... fuel light came on (had just left the petrol station so it was full) guessing the fault triggered the ecu to stop sending the fuel pump the message to pump.
When it does not start;
Can hear the starter turn (just been reconditioned)
No immobiliser (Japanese model)
Inertia switch in normal position
Checked voltage at fuel pump, inertia switch and fuel relay - no power there
Where to check the ecu?
Or possibly the heat of the engine (block) is affecting a sensor - crank? When it doesnt start I cant hear the fuel pump - Im guessing the fuel lines are still primed as the car and pump have been going but the ecu is not getting the message from the faulty crank sensor and so wont tell the pump to go?
Also noticed the red vacuum hose from the back of the throttle body is not connected to the air box ... broken end in need of replacing all probably. Where is the best place to source a vacuum hoses?
Last step before I find a specialist mini guy ... in NZ
Posted 19 October 2017 - 11:41 AM
>>>>>>>>Or possibly the heat of the engine (block) is affecting a sensor - crank? <<<<<<<<
Similar case happened to me, changed the crank sensor, back to normal.
Posted 19 October 2017 - 01:09 PM
If the crank sensor is acting up, the RPM readings should be erratic or not existing while cranking.
Posted 19 October 2017 - 01:26 PM
The fuel pump won't run until the ECU registers that the engine is turning. That means testing for voltage at the relay, the inertia switch and the fuel pump will not return any voltage reading.
The Fuel pump will start for a second or so every time you turn the key to IGN. If it does, then it is perhaps the crank sensor, as they do sometimes get affected by the heat.
Edited by Sprocket, 19 October 2017 - 01:27 PM.
Posted 19 October 2017 - 11:06 PM
