Missing Bit On New Boot Floor
11 replies to this topic
#1 pete l
pete l
  • 1,360 posts
Posted 20 October 2017 - 02:41 PM
Hi all,
I bought a new boot floor from mini spares a couple of weeks ago and have just realised that the reinforcment metal along the front of the rear seat part is missing.Between the 2 storage bins.It's really quite floppy without it !
I can't find it for sale anywhere, should it have been there ? do I have to bodge it up with a metal strip ?
#2 Itsaminithing
Itsaminithing
  • 851 posts
  • Local Club: Not One Worth Mentioning
Posted 20 October 2017 - 03:01 PM
Do you mean the seat pan edge reinforcement (part number 14A6672)
Somerfords: http://www.somerford...&id=1&chapter=5
#3 GT Jimmy
GT Jimmy
  • 1,583 posts
  • Local Club: S.U.N.M.C
Posted 20 October 2017 - 03:32 PM
Wasn't on my boot floor either, I didn't realise a bit was missing. Just checked what I cut out and sure enough it's there
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,899 posts
  • Name: Neil
Posted 20 October 2017 - 04:03 PM
Yup none of them come with it fitted. Poor form really. Made both of mine myself. Bit of cheek really paying for a bit of folded thin metal which should have come fitted already in my eyes. The panel is expensive as it is.
#5 pete l
pete l
  • 1,360 posts
Posted 23 October 2017 - 07:47 AM
Looks like I'm going to have to make something up then, thanks for your replies.
#6 GT Jimmy
GT Jimmy
  • 1,583 posts
Posted 26 October 2017 - 05:16 PM
How much would the piece be? Don't fancy my chances of bending a piece of steel straight enough lol
#7 sonikk4
sonikk4
  • 15,899 posts
  • Name: Neil
Posted 26 October 2017 - 06:05 PM
Somerford mini. Pt no. 14A6672 £14.27
#8 GT Jimmy
GT Jimmy
  • 1,583 posts
Posted 26 October 2017 - 07:15 PM
Cheers Neil
#9 jamesquintin
jamesquintin
  • 1,017 posts
Posted 28 October 2017 - 07:54 PM
you'll also be missing the cage holding the negative cable nut, the bracket for the fuel tank strap, the tags to hold the wiring loom down, and if you're really picky, the two plates by the side of the arches
#10 pete l
pete l
  • 1,360 posts
Posted 30 October 2017 - 07:40 AM
On that note James, any idea how I can get the petrol tank bracket in the right place ? are there measurements around to help me ?
And I'm still debating whether to put the two plates back on
Edited by pete l, 30 October 2017 - 07:41 AM.
#11 jamesquintin
jamesquintin
  • 1,017 posts
Posted 31 October 2017 - 06:09 PM
I used the original corner with the bracket still attached to get the correct position (I bought a new bracket, wasn't sure how to save brackets as the first bit of bodywork I had undertaken).
If you don't have a reference you would have to put the boot floor in the car, put the tank in with the bracket and clamp the bracket down through the rear light hole?
I only put the brackets on as I'm anal and wanted 100% originality... The plates are under where the seat base and the arch bracket are. Maybe the plates add strength?
Q
#12 CBJ805T
CBJ805T
  • 430 posts
Posted 31 October 2017 - 10:49 PM
Darn this photobucket fashilz!
Hope this helps
Chris
Edited by CBJ805T, 31 October 2017 - 10:55 PM.
