Folks, I have just rebuilt my MPI. Itr ran before I dismantled it.I have now got it running but it takes a good deal of coaxing in to life. When it does finally fire up if I touch the throttle more than a whisker it dies. After several tries and coaxing the throttle just as it catches the car will eventually tick over reasonably well or a moderate amount of time. If I try to rev the car up it dies unless I gingerly tap the throttle and catch it just right. From there I can build up the revs to a maximum of just under 3000 rpm. It then backfires occasionally.
I took the clutch and flywheel out. I could only see one orientation of the flywheel but i wondered if the clutch and pressure plate have to go in a certain way? If so how do I do this correctly.
The timing appears to be out to my mind. Not at all familiar with MPI Minis
Any suggestions welcomed. Cheers. Mark
