Metro Air Box
Posted 22 October 2017 - 06:23 PM
Posted 22 October 2017 - 06:38 PM
why not just get a Mini one?
if not changing it just use as is. cant see it being an issue.
Posted 22 October 2017 - 06:44 PM
Because thats no fun. You dont think the fan would be robbing air from the filter entry? (Im no aerodynamicist, Im guessing.)
Posted 22 October 2017 - 06:46 PM
Posted 22 October 2017 - 06:48 PM
Posted 22 October 2017 - 07:05 PM
Posted 22 October 2017 - 07:06 PM
Posted 22 October 2017 - 09:45 PM
The same casing "cooperised" by Rover
Posted 23 October 2017 - 06:50 AM
get the austin metro type inlet box instead (if the pipe fits between the brake servo and engine). that comes around the engine and has inlet in front of the engine.
Posted 23 October 2017 - 12:25 PM
Looks like they were pretty desperate to get the air from somewhere else then- I think I'll have a play!
Posted 23 October 2017 - 01:07 PM
Air wasnt important. New drive by noise laws made them do it 😊
Posted 23 October 2017 - 07:18 PM
So what do you think? Cut an inlet on the other side, or should it not matter?
Posted 23 October 2017 - 08:57 PM
Why not go the whole '60s boy racer and drill a few
Like mine
Posted 24 October 2017 - 12:24 AM
Are we we back to the original question? The filter element is offset away from the intake so air can flow to all of it. Cutting a hole elsewhere won't have that gradual reduction in area going away from the air inlet. A pipe could work well, the smoother its surface the better. Are you plumbing in the vacuum operated hot air flap?
Posted 24 October 2017 - 05:33 AM
I dont have the flap, all I have at the minute is the air box as above, with the inlet facing the radiator. The question is, is this the best direction to be drawing air from? Or should I modify the air box to draw air from the other side of the engine?
