So, I'm rebuilding two trailing arms. Have new pivot pins with new bearings, reamed bushes & grease tubes. So far so good. Add the backing plates & cable guides. Go on to assemble the first brake components - new shoes, new springs, new adjuster & wedges.
Problem arises...NEW adjuster will NOT thread through the backing plate & the square head is too big for 5/16" brake wrench. (wedges fit fine)
More junk from the 'martians'?
Any ideas out there??
