Okay no probs cheers , Ive noticed when I change from car to screen the heater flap dosnt seal very well and Ive noticed when I cover the gaps with my hands that the air coming from the vents is much more powerful and efficient any body got any ideas on how to seal it better and stop air leaking around the flap ?
It's not a great design, it might be more effective to add a flap to stop the air exiting from the heater. If you're crafty you might manage to make the heater flap open it...
Inner flaps seals against the matrix. Outer flap is larger and seals against a frame between the screen and car vents. The inner flap pushes the outer flap open as it's set from screen to car. A spring could return it - or gravity and magnetic rubber (e.g. fridge door) to hold it shut.
