Need some tech advice. Got the newly rebuilt engine in, and the car won't start. I can hear the starter clicking and engaging but nothing after that. I also have a brand new battery giving me enough volts to crank it over. I even thought maybe to place it in gear and rock the car to move the cylinders and still nothing. Any suggestions? Oh one more thing, I went from inertia starter to pre engaged starter. Thanks
Initial Start Woes.....
Best Answer MiniMoe2008 , 29 November 2017 - 04:40 PM
Yes. LOL I posted this immediately after i posted it on face book. I'll do that tonight.
Go to the full post#1
Posted 05 November 2017 - 05:13 PM
Posted 05 November 2017 - 05:24 PM
Posted 05 November 2017 - 05:33 PM
so you changed to a suitable flywheel?
you checked it rotated before fitting the cover?
you used the correct length bolts for the clutch bracket and engine mount? too long and they can lock the flywheel.
Posted 05 November 2017 - 05:57 PM
You have turned it over by hand first haven't you to make sure you haven't done anything dim. Does it turn over by hand with the plugs out ?
Yes sir it does. I was able to turn the crankshaft with no problem.
Posted 05 November 2017 - 06:00 PM
So the engine I had rebuilt was a spare A+ engine i had from my other mini. What my mini originally had was an A series. NOT the same engine rebuilt.
Posted 05 November 2017 - 06:08 PM
Posted 05 November 2017 - 06:25 PM
Have you checked the earth wires?
I have one going from the clutch cover to the bottom steady bar on the subframe. Do i need to add another one?
Posted 05 November 2017 - 07:06 PM
you used the correct length bolts for the clutch bracket and engine mount? too long and they can lock the flywheel.So the engine I had rebuilt was a spare A+ engine i had from my other mini. What my mini originally had was an A series. NOT the same engine rebuilt.
so what about the other questions.
Posted 05 November 2017 - 07:15 PM
Clutch bracket? Can you give me an example? i dont know what ypu are taking about.
Posted 05 November 2017 - 07:25 PM
Posted 05 November 2017 - 07:35 PM
You need to earth to the BODY not a rubber mounted subframe.
Posted 05 November 2017 - 07:46 PM
I agree with this.
I have mine from the wok to the inner wing(shiny metal on inner wing) then covered with clear grease
Posted 05 November 2017 - 07:48 PM
I rotated the crank which means yes the flywheel turned.
so you can rotate the flywheel with the starter removed? by using a big screwdriver.
I do hve it to the body. I have it on the bracket side, NOT the bushing side of bottom mountYou need to earth to the BODY not a rubber mounted subframe.I have one going from the clutch cover to the bottom steady bar on the subframe. Do i need to add another one?Have you checked the earth wires?
Posted 05 November 2017 - 08:22 PM
The subframe is still rubber mounted though, so the engine isn't earthed
