Are you using the correct terminal on the starter for your switch? The tripper terminal on the starter solenoid is the large flat spade connector, not the small one as you might suspect. A screwdriver from the top battery terminal on the starter to the large flat spade connector should make it crank over properly.
Edited by Magneto, 29 November 2017 - 03:49 PM.
