Advice Please
25 replies to this topic
#1 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 09 November 2017 - 08:06 AM
I have got a 1989 mini with verto clutch
When it was in gear I put a socket  on the big nut that holds the flywheel  on and it was moving  freely  with no
Resistance is this normal as I thought  it should show  signs  of it being  in gear?????
Any thoughts  thanks
#2 Carlos W
Carlos W
  • 10,110 posts
Posted 09 November 2017 - 08:23 AM
The big nut doesn't hold the flywheel on.
Have a look in the haynes manual about proper adjustment as I don't hink it should be that loose
#3 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 09 November 2017 - 11:52 AM
Thanks for your reply
The car will not go into gear while the engine  is running
the big nut is the one that holds the clutch  onto the engine
Also the engine is making  strange  noises   ??
#4 nicklouse
  • 17,944 posts
Posted 09 November 2017 - 12:00 PM
which big "nut"?
the fly wheel is not held on by any nuts,
#5 nicklouse
  • 17,944 posts
Posted 09 November 2017 - 12:02 PM
if you mean the throw stop nuts there should be a few degrees of free movement but if you can move it more that 10 degrees and the plunger is also moving then the arm may well have failed.
#6 Rorf
Rorf
  • 859 posts
Posted 09 November 2017 - 12:34 PM
It would help if the OP gave us a photo of this nut so we know what he is talking about :D
#7 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 09 November 2017 - 01:53 PM
Its the one that holds the clutch  onto the engine
#8 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 09 November 2017 - 01:56 PM
The clutch isn't held onto the engine, it sits on the crankshaft tail. Have you removed the wok? You need to post a picture.
#9 Pigeonto
Pigeonto
  • 967 posts
  • Local Club: ISMOC
Posted 09 November 2017 - 02:30 PM
Mini1955 :- Is it that you  mean bolt when you are saying "Nut" that holds the clutch on ?
#10 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 09 November 2017 - 03:19 PM
He needs to post a picture!
#11 Rorf
Rorf
  • 859 posts
Posted 10 November 2017 - 03:13 PM
Mini 1955 we haven't solved your problem yet.
#12 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 10 November 2017 - 03:16 PM
I meant  the bolt that  hold the clutch  and flywheel the one behind  the wok
#13 nicklouse
  • 17,944 posts
Posted 10 November 2017 - 03:20 PM
that bolt should be very very tight.
#14 nicklouse
  • 17,944 posts
Posted 10 November 2017 - 03:21 PM
have a read
http://www.theminifo...revving-engine/
#15 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 10 November 2017 - 03:23 PM
When you turn it, does the engine turn over or, is it just turning in the end of the crankshaft?
