Advice Please
25 replies to this topic
#16 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 10 November 2017 - 03:24 PM
Mini1955 :- Is it that you  mean bolt when you are saying "Nut" that holds the clutch on ?
Thanks  for noticing I maid a mistake
#17 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 10 November 2017 - 03:27 PM
I meant  the bolt that  hold the clutch  and flywheel the one behind  the wok
When you turn it, does the engine turn over or, is it just turning in the end of the crankshaft?
It seems to be only  the crank  cannot get any gears when engine  is running
#18 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 10 November 2017 - 03:33 PM
So, are you saying when you put a socket on the bolt head and turn it, the engine turns over?
#19 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 10 November 2017 - 03:43 PM
Yes but as the car is in gear should  it do that
#20 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 10 November 2017 - 03:48 PM
No it should'nt, you say above you can't get any gears when the engine is running, do you mean you can't get it into gear or, do you mean when you've selected a gear you don't get any drive?
#21 nicklouse
  • 17,899 posts
Posted 10 November 2017 - 03:55 PM
not unless the clutch is totally dead and slipping. or you are making the wheels move by doing it. it should only move along with the flywheel.
#22 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 10 November 2017 - 03:56 PM
   can't get any gears
#23 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 10 November 2017 - 03:59 PM
   can't get any gears
You must have missed my post number 20, what's the answer to the questions I asked?
#24 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 10 November 2017 - 04:05 PM
With the car in gear if you try and turn the flywheel over with a socket  on it it moves very freely  like it's not in gear
With the engine  running  it will not select  any gears
#25 Ethel
  • 25,379 posts
Posted 10 November 2017 - 07:22 PM
So you took the cover off because it wouldn't select gears?
It should never be that easy to turn the flywheel bolt as you'd also be turning the engine over, looking at the crankshaft pulley on the radiator end will tell you if that's happening.
People have asked if the stick moves as if it's going in to gear or you physically can't move the stick, apart from across neutral, when the engine's running. It helps diagnosis as the stick would resist going in to gear if the clutch was still driving the input side of the gearbox.
You could jack a front wheel off the ground and turn it to confirm if the engine is connected to it when you can get it in gear when it not running. Only one, if both are off the floor you'll be turning the other wheel and testing the diff.
Any history from when it stopped working? Did you notice what the speedo did, such as not registering when the car was moving or still registering when the car was motionless?
#26 mini1955
mini1955
  • Area Managers
  • 537 posts
Posted 10 November 2017 - 08:03 PM
Thanks for the advice  will start checking  again
