Posted 09 November 2017 - 10:30 PM
Completely out of ideas and talent please any pointers and courses
Posted 09 November 2017 - 10:33 PM
Hi Mr Frosty. Did you bleed the clutch slave cylinder?
Posted 09 November 2017 - 10:34 PM
Posted 09 November 2017 - 10:46 PM
Posted 09 November 2017 - 11:01 PM
If there isn't enough clearance on the end float or,if you've fitted a new one and it's not machined correctly as it get hot it will expand and stick on the crank leaving the primary gears in constant mesh even though the clutch is disengaged.To be honest no idea that part was a while ago. I will need to revisit me thinks. Excuse my ignorance Why would it stop the disengaging?
Posted 09 November 2017 - 11:15 PM
That has happened to a lot of people due to the change of primary gear bush material some time ago. The latest after-market bushes need to be machined with a bit more radial clearance to prevent the primary gear from 'seizing' onto the crankshaft.
as Tom Jones would say, "It's not unusual" .
Posted 09 November 2017 - 11:31 PM
apart it comes again, this car hates me I'm sure. It only took four attempts to sort the duplex cover sorted.
Posted 09 November 2017 - 11:36 PM
You don't need to take it apart to check it. Once you're convinced it's not a hydraulic issue with a liitle work you can check it in situ. Remove the wok and take the flywheel off. Check the primary gear spins freely and then check the end float. You're looking for between 3 and 6 thou clearance.Thanks for your help.
Posted 19 November 2017 - 10:30 PM
Only brakes seat belts and get indicator working she will be ready
Posted 19 November 2017 - 10:46 PM
So what was the fault when you took it apart?So after checking end float ando running again clutch still not disengaging. So out came the engine. Stripped cleaned polished an repeat. Rebuilt swore at it and it's all good now. Thanks for your assistance.
Posted 20 November 2017 - 10:02 PM
Probably throw it together too quickly the first time. It's been twenty years between this engine and my last rebuild
Posted 26 November 2017 - 05:50 PM
Clutch I's coming out again.
Pritty much roled out most things need to look at the clutch assembly again. Any body got any ideas
Posted 27 November 2017 - 09:13 PM
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
