Hi folks, a quick and easy one for you engine builders out there...
Should there be a gasket on the bottom of the rocker post(s) in particular the one with the oil feed through it?
Sure enough there hasn't been on the engines i've stripped, and i can't find one advertised anywhere, it just looked a bit odd putting it together without one.
I guess it'd have to be all of them or nothing to keep the shaft perfectly straight...
I'm sure theres a good reason for it not to be there...?
Jon
