Got a bit more done after my gas bottle running out almost instantly on the Saturday before last.
Started by cleaning up then setting the healboard up by bolting to the subframe then holding it in place with a couple of screws.
20181103_105312 by Stuart gaylor, on Flickr
Got a couple of plug welds in before like I said the bottle run out so cut out the drivers floor as to be honest it wasn't doing much anyway.
Trimmed a bit off the half floor to get it to sit better and clamped the step panel in to see how it all lined up.
Will need some more fettling but was only a trial fit
20181103_132616 by Stuart gaylor, on Flickr
Not much heal board left but I have a new one to fit before I fit the floor.
20181103_132623 by Stuart gaylor, on Flickr
Then moving on to this Saturday just gone I got some more gas and plug welded the healboard using the holes I drilled to remove the old one
20181110_113721 by Stuart gaylor, on Flickr
20181110_113730 by Stuart gaylor, on Flickr
20181110_113739 by Stuart gaylor, on Flickr
Bit out of practice with the mig as haven't used one for ages but did get good penetration so should be nice and strong.
After a bit of a grind up and a coat of zinc primer, does need cleaning up a bit more though
20181110_115052 by Stuart gaylor, on Flickr
20181110_115045 by Stuart gaylor, on Flickr
Then back on its side
20181110_121620 by Stuart gaylor, on Flickr
Subframe out
20181110_123834 by Stuart gaylor, on Flickr
Now time to tackle the toeboard (or lack of it)
Even the peddles are rusty and pitted but I have another pair somewhere
20181110_115535 by Stuart gaylor, on Flickr
20181110_123829 by Stuart gaylor, on Flickr
Started drilling the spot welds on the toeboard
20181110_135019 by Stuart gaylor, on Flickr
20181110_135033 by Stuart gaylor, on Flickr
So that's about as far as I got over the weekend
Next week hopefully get the toeboard out and do a couple of repairs where it joins before fitting the new one
