The car is still on the boat crossing the pond so I only have pics to go by.
Gotcha
#16
Posted 14 December 2017 - 01:42 AM
#17
Posted 14 December 2017 - 01:54 AM
I did a little googling. Seems the jap spi might use a coilpack of some sort however it may be different that the uk mpi parts.
Half the fun/frustration of this car will be figuring out what uk parts work
the Jap spec cars were a mix of MPI and SPI
they were different to the UK spec cars but nothing much that was not used elsewhere.
#18
Posted 14 December 2017 - 11:35 AM
There are a few items on the car that are specific to the aircon models and pretty much all of them are no longer available or difficult to come by second hand. Get yourself a grease gun to make sure all points are fully lubricated - its something that often goes over looked for new mini owners.
#19
Posted 14 December 2017 - 10:20 PM
any good sites to compare part numbers from uk to Jap, so I dont keep ordering the wrong parts.
Thanks for the advice
#20
Posted 14 December 2017 - 11:25 PM
look in the SPi MPi section but like i said there is little that is special.
#21
Posted 15 December 2017 - 09:44 AM
MPi block fitted with SPi injection system. Service it with normal SPi parts except you don’t need a distributor cap and rotor.
Do replace all vacuum pipes and fuel trap as these are also service items and you want to be sure they are in good order to prevent fuelling issues. Fuel filter on rear subframe should be changed but you’ll need to wait until it arrives to check which one is fitted.
Normal mini servicing plugs tappets oil, grease points etc plus I would give it a heavy dose of wax underneath and in in all box sections to keep the rust at bay I use bilthamber products on mine.
Looks nice..enjoy
FS
