Front End
Posted 19 November 2017 - 07:57 AM
Posted 19 November 2017 - 08:37 AM
Posted 19 November 2017 - 09:06 AM
Posted 19 November 2017 - 09:13 AM
Posted 19 November 2017 - 09:24 AM
The front panel to wing is a little harder but again doable for plug welding. Now due to the width of flanges on the wings to front panel the holes again no bigger than 3/16th if plug welding. The flanges tend to be small especially on the radiuses. A good light source is essential here and a reactive welding mask. Think about how you can see the flange you want to weld, so once the panel is temp fitted and NO holes drilled then get in their with welding torch and see what access YOU can achieve comfortably. Also think about where you can get a grinder, Powerfile, die grinder etc to clean up the plug welds. Once you are happy then drill the holes on the side you can access.
Now if you have a spot welder then it is straight fwd.
Posted 19 November 2017 - 09:30 AM
Posted 19 November 2017 - 10:17 AM
Made welding the flanges much easier.
Posted 19 November 2017 - 01:52 PM
Thanks Neil by the way got both doors looking the same but both have that gap at the top corner at the screen ?
What’s the rear of the window frame like??
Posted 19 November 2017 - 05:25 PM
Hi Neil do you mean the door frame ?
Posted 19 November 2017 - 07:06 PM
Yes indeedy.
Posted 19 November 2017 - 08:55 PM
Edited by I hate Brian, 19 November 2017 - 08:56 PM.
Posted 19 November 2017 - 09:04 PM
Ill have to check tomorrow thanks for replying, by the way where is Stone Cross ? is it near Saxmundham passed through there in summer.
Just outside Eastbourne.
Posted 20 November 2017 - 07:16 AM
Wow that far down, I'm sure you had Saxmundham on your profile ?
Posted 20 November 2017 - 06:43 PM
The closest i have ever been to there was when i used to work in Cambridge. I used to live just outside Peterborough in a small village called Glinton and prior to that just up the road in Market Deeping.
Posted 20 November 2017 - 07:21 PM
Hi Neil this was an original picture of the car prior to any work
