Due to a lack of power in my garage, only got a few mins on it after work. With the bleed nipple open, the pedal goes to the floor easily, so the master and flexi are off the hook.
With the nipple tight, the pedal goes down further, but is heavy still and I can't get it down to the carpet.
Plus with the stop wound in, if I try and push the armback to it, it springs back. So have unbolted the slave and now I get the slack I'd expect and could readjust the stop. It has ended up back to where it was before I wound it in, so that suggests to me that everything inside the wok is where it was before the problems started.
So this is leading me towards the slave dying, which is partly reinforced as there is some black residue on the shaft which wasn't there when we dropped the engine back in.
Edited by craig 1010cc, 20 November 2017 - 04:40 PM.
